Author Topic: Reversed biased diode for beeper...  (Read 1308 times)
Offline alank2Topic starter
« on: July 06, 2015, 02:51:54 pm »
I'm using a PZT2222 to drive a "5V active beeper" that I bought off eBay.  I recall using these in the past and didn't notice much of a kick back when turning one off, but I just took a look at it with my scope and it shows a 200ns pulse of 63V.  The PZT2222 data sheet says the CE voltage max is 40V.  Does this mean I need to use a reversed biased diode?  Is 200ns short enough that it isn't necessary?
Offline rs20
Re: Reversed biased diode for beeper...
« Reply #1 on: July 06, 2015, 03:06:03 pm »
I haven't heard the concept of a pulse being too short to be damaging... it might slow down the damage perhaps, but I'd be putting the diode there if I were you. Maybe I'm overly conservative though.
