Author Topic: Amplifier transistor circuit (positive feedback)  (Read 2041 times)
Offline yalectTopic starter
« on: March 07, 2015, 02:22:35 pm »
Hello,
I would like to ask you if a capacitor connected between the collector and  the Emitter of transistor can's work like positive feedback as shown on my attached circuit or that can’s decrease the output signal? if it doeshow it’s calculated?
Thank you
« Last Edit: December 13, 2021, 08:51:25 pm by yalect »
Offline Zero999
  • 0999
Re: Amplifier transistor circuit (positive feedback)
« Reply #1 on: March 08, 2015, 12:08:07 am »
Why not simulate it in SPICE software and see?
Just looking at it, I'd say not.
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: March 08, 2015, 04:14:07 am »
Yes, but only at radio frequencies.  And it acts as a capacitive divider against base-emitter capacitance, which means the base should have some capacitance to ground, so the transistor acts somewhat like a common-base amplifier (regarding the feedback anyway).
The usual purpose is making an oscillator with an operating frequency near the transistor fT.
Seven Transistor Labs, LLC
« Reply #3 on: March 09, 2015, 02:44:31 pm »
Hello, thank you for your reply
You said, the base should have some capacitance to ground, why? and can you explain more how it acts as a capacitive divider against base-emitter capacitance?
Regards
