Hello,
This is not a repair how to request, but a request for knowledge, or at least, where I might find it.
Recently I acquired a bench power supply, maybe for just the right price too. But only if I can fathom a few issues.
In the power supply circuit is a LM317T and a LM320T in a mirror image arrangement. They should output +15, & -15V about a common 0V ground.
The LM320 output is -17.97V. This is with the trim potentiometer turned fully one way.
About the only component in the schematic that I think will make much difference is if R320 drifts. However, it measures to within 1% of 820 Ohms.
The outputs from this supply are connected to the various circuits via wire links on the board. In order to see what influence downstream circuits may be having, I lifted the -15V link. This had the effect of lowering the voltage even further, down to -30VDC.
If the output were weak, I would think that there's a current path that has become less of an impedance, or a short has developed. But no. The voltage is more negative and I don't quite get how that occurs. In my rather limited experience, regulator IC's should be capable of a pretty stable and accurate output if the controlling dividing network is set up correctly.
I would very much appreciate any advice in trying to determine what is happening here.
Attached is the schematic of the circuit in question. Pencilled in are actual voltages found, except the -30V.
