Yo folks,
So have some old technology here, vintage old school active hi-fi speakers. Some revisions have a smaller device connector hole, it turns out.
I modded older revisions of them and threw away the C10 from the 1970s because a C10 connector
1. is not at all universal and if you lose the cable you're screwed
2. the freaking cable costs me at least 3 times the price of a normal C13 cable with a length of 2 meters.
I wanted to enlarge the mounting hole only a few mm / inch, but the metal back plate is 3 mm or 0,11811 inch thick! I think my dremel is too weak for this, and I don't want to mess it up an angle grinder, of course this wouldn't work anyway because an angle grinder is not meant for such small dimensions...
The dimensions of the mounting hole:
C14 just doesn't fit, I tried to file some ABS plastic away from a C14 connector and finally I went through the damn thing, so this won't work either.
Any other ideas?
