Author Topic: Wind mill controller reverse engineering  (Read 1247 times)
Offline somlioyTopic starter
  • Country: no
« on: May 27, 2016, 03:25:08 pm »
Hello
I got a wind mill controller that was fried somehow and the model is out of production so I thought it'd be a great exercise to create a new one. I've traced out the power circuits but I'm not quite sure whats going on. I'd be greatful if someone can explain. What I dont get is how the negative is created.
The stator has three phases. Wind mill output is supposed to be 12V.
The gate of the mosfets are going to a microcontroller or something, 32 pin TQFP-package I believe. The top is scraped off, but there's a 3.579545 Mhz crystal nearby going to pin 3/4.
Anyway, see attached image for schematic.
Online NiHaoMike
    • Facebook Page
Re: Wind mill controller reverse engineering
« Reply #1 on: May 28, 2016, 12:04:25 am »
It's actually a boost converter that doesn't look like one at first glance.
http://techno-fandom.org/~hobbit/cars/boost-hack/
The following users thanked this post: somlioy
  • Country: no
« Reply #2 on: May 28, 2016, 08:54:36 am »
That's quite clever. Is it possible to regulate the "dc bus" to a constant charging voltage with these components and how does the mcu know when to fire the mosfets?
