Just for fun I tried that 3 opamp filter using emitter followers instead of opamps. PN100s with a 1K source resistor. Not DC accurate anymore, but the rolloff really gets with it! Keeps on going down to 90kHz. 4V input becomes 10uV @ 90kHz.
Here's a version using complementary emitter followers that is
somewhat DC accurate with ~30mV offset. The
amplitude response is somewhere between a Butterworth and Bessel as shown in simulations, however the phase response is almost identical to the Butterworth in the range shown. We included a DC Accurate (op-amp) and Sallen-Key for comparison and even did some Bode measurements of such, including the single transistor version
All these filters use the same 10kΩ and 0.01uF for the frequency determining elements which places the "corner" frequency at 10krad/s (1.59kHz).
BTW the sim "E" VCVS sources are included to allow normalizing the gain of all the LPFs to the Emitter Follower gain which is ~0.9 as shown.
Anyway, just another version of these filters, hopefully other's will find this stuff interesting.
Best
