For a simple go/no go test, I usually just hook the drain and source up to a bench power supply with a lamp in series. Touch the gate with one hand, and the positive terminal of the PSU with the other (assuming N-channel), and the lamp should go on, now touch the negative terminal and it should go off again. While this is a fairly crude test, in my experience MOSFETS usually either work or they don't - you don't really need to know any more.
Make sure that you take appropriate antistatic precautions with the above test.
Hope this helps,
John
