Is this supposed to mean that the Fluke has at best 0.1V resolution on DC volts? Well, that wouldn't be my first choice of a budget DMM for breadboard circuits...
Yes, that's what I mean...its not my choice I really only have it as a backup in my kit bag, and only really get uses as a continuity tester, would be interested in what you pick would be as my Extech EX330 just died after many years.
I gather it all means that the test current from the camera is so low that when the switch around 39kΩ is closed, there is less than 100mV voltage drop across the remaining 2.2kΩ resistor. If the camera requires this drop to be less than 0.7V then you have got a problem. No Darlington configuration of any sort is going to work.
Thank you for explaining this, my experience with Darlington configuration has been limited to audio applications.
What may possibly work is to go back to just two resistors and then connect the phototransistor right across the camera terminals, bypassing all resistors. Or experiment with smaller values instead of 2k2.
I like this idea, fewer parts and just swapping resistor value, now we are at my level of skill!
If the Panasonic guys have any brain, the camera should not be harmed even by a short between the two terminals. Indeed, such short often occurs during insertion of that kind of jack into the socket or it could happen due to cable damage or similar reasons. And your phototransistor doesn't seem capable of conducting much current anyway.
Oh, I'm 100% sure I shotted them together when working on the first switch as my previous experience had been with Canon cameras that just use a short to trigger.
Thank you so much for taking the time to help me out with this, its sincerely appreciated and teaching me a fair bit too!
