You mean if the voltage divider is there, the EN pin is driven by it (the voltage divider) via VDD?
If only R5 is mounted, the 3.3V buck is always on
If only R9 is mounted, the 3.3V buck is always off (this is redundant as there is already internal pulldown)
If both R5 and R9 are mounted, the 3.3V buck will only turn on when the voltage on EN is above 0.9V so you can choose R5 and R9 values to set the minimum VDD at which the 3.3V turns on (UVLO)
If R6 is mounted, the 3.3V buck will be enabled by SYS_PG, in this case R5 can only be mounted if SYS_PG can withstand the VDD voltage.
The schematic shows that only R6 is mounted, so 3.3V is controlled from SYS_PG
