Author Topic: Any info on this intel F32-408833 IC?  (Read 713 times)
Offline ELS122Topic starter
« on: October 04, 2022, 11:51:34 am »
it hints that it's licenced from intel, made by winfield.
WINFIELD
F32-408833-40
GER
INTEL(M)(C)1980
it's from an electronic typewriter, I'm building a winding machine and was thinking of using this to control it, since a winder is basically a typewriter but faster right?  ;D
I can't find any info on it, at first I thought it was some 8088 de-graded clone but nothing lines up.
it drives stepper motors trough a ULN2003A driver chips, also has a keyboard that connects directly trough it so it obviously is capable of doing some kind of multiplexing.
crystal is 12khz, connects to pins 18 and 19
ground connects to pin20, +5V to pins 20 and 31. it's a DIP40 package
I'll draw a schematic of the board if it helps
any info on this or even just a similar IC would be helpful!
« Last Edit: October 04, 2022, 11:54:07 am by ELS122 »
Re: Any info on this intel F32-408833 IC?
« Reply #1 on: October 04, 2022, 12:35:17 pm »
sorry, forgot to add the picture of the IC (weird angle because the part number didnt wanna comply in the light)
Offline chickenHeadKnob
« Reply #2 on: October 04, 2022, 12:56:30 pm »
I would lay a bet that it is a custom mask programmed 8051.
The following users thanked this post: ELS122
« Reply #3 on: October 04, 2022, 01:01:07 pm »
yup! all the pins check out, gotta be it!
Offline wraper
  • Country: lv
« Reply #4 on: October 04, 2022, 01:02:49 pm »
Yes, considering 1980 copyright date, this thing should at least have 8051 core, more likely just a usual 8051 with mask rom. i logo implies it was made by intel. Likely you can even read its ROM.
« Reply #5 on: October 04, 2022, 01:05:18 pm »
the datasheet says it's has an EPROM, this is Electronically Programmable ROM not Erasable, Programmable ROM right, was hoping to reprogram it  :D
Offline wraper
  • Country: lv
« Reply #6 on: October 04, 2022, 01:11:21 pm »
8031 has no ROM, 8051 has mask ROM, 8751 has OTP EPROM (programmable only once). Only 8751 with quartz window (not usual plastic one) can be reprogrammed after UV erase.
« Last Edit: October 04, 2022, 01:13:20 pm by wraper »
