Author Topic: Any MOSFET similar of ULN2003?  (Read 21116 times)
Offline zaptaTopic starter
« on: August 25, 2015, 07:38:59 am »
The ULN2003 has multiple channels (I need only 4), can be driven directly from 5V MCU and has protection diodes for inductive load (e.g. 28BYJ-48 stepper motor) but has high saturation voltage because of the darlington driver. Is there a similar MOSFET IC, with closer to zero saturation voltage?
Offline Psi
Re: Any MOSFET similar of ULN2003?
« Reply #1 on: August 25, 2015, 07:57:24 am »
what current do you need to switch?
Maybe this?
http://www.digikey.com/product-detail/en/BTS4130QGA/BTS4130QGACT-ND/2231089
Search digikey in the "PMIC - Power Distribution Switches" section.
There are lots of multichannel driver ICs that have built in fets and accept logic level input.
Many are intended to drive inductive loads and dont need a back emf diode
« Last Edit: August 25, 2015, 08:00:57 am by Psi »
Offline Zero999
  • 0999
Offline bingo600
« Reply #3 on: August 25, 2015, 08:04:07 am »
Maybe the   TI TPIC family of power arrays
Ie. (Or see companion prods in bottom)
http://www.ti.com/product/tpic6259
/Bingo
« Reply #4 on: August 25, 2015, 02:00:43 pm »
100ma per channel at 2 out of the 4 channel, plus some margin.  This is to operate this stepper motor http://robocraft.ru/files/datasheet/28BYJ-48.pdf on 5V USB power.
http://www.ti.com/lit/ds/symlink/tpic2701.pdf
Yes, this is what I looked for. Will give it a try. Thanks.
« Reply #5 on: August 25, 2015, 02:12:18 pm »
Tried to source it but Digiky and the other distributors don't carry it. Is it discontinued? Any new replacement?
(I am not interested in ebay or China only ICs).
Edit:  found this one http://www.digikey.com/product-detail/en/TPL7407LDR/296-37284-1-ND/4733033
« Last Edit: August 25, 2015, 02:20:29 pm by zapta »
The following users thanked this post: oPossum
Offline ElektroQuark
    • ElektroQuark
« Reply #6 on: August 25, 2015, 02:29:30 pm »
TI's web says TPIC2701 is obsolete. No replacement. So forget about it.
Offline ralphd
    • Nerd Ralph
« Reply #7 on: August 25, 2015, 02:29:51 pm »
Since you only need 100mA per channel, what about 4 x 2222a?  Cheap and widely available, and VCE(sat) @100mA collector current should be <0.2V.
https://www.fairchildsemi.com/datasheets/PN/PN2222A.pdf
Unthinking respect for authority is the greatest enemy of truth. Einstein
Offline dom0
« Reply #8 on: August 25, 2015, 03:07:21 pm »
tpic6b595, has the shifter built in.
« Reply #9 on: September 20, 2015, 07:23:30 pm »
Just realized that the TPL7407L can't replace the ULN2003 in my application because it requires a voltage of at least 8.5V and my circuit has only 5V.
Offline LukeW
« Reply #10 on: September 20, 2015, 08:58:16 pm »
Only 100mA?
Why not just any small cheap FET, eg. 2N7002? If you need a flyback diode, add one externally. Or you could choose jellybean BJTs if you don't like FETs.
« Reply #11 on: September 20, 2015, 09:05:12 pm »
Only 100mA?
Yes, I could do that, 4 FETs or pre-biased BJTs and 4 diodes. It's easier though to manually pick and place a single component.
Offline tom66
« Reply #12 on: September 20, 2015, 09:32:22 pm »
Something like a dual N-channel MOSFET in SOT26?
Two pieces of this ought to work:
http://docs-europe.electrocomponents.com/webdocs/104e/0900766b8104e4cc.pdf
Offline nctnico
« Reply #13 on: September 20, 2015, 09:37:00 pm »
Only 100mA?
If the device has an internal diode (and all mosfets have one) you can do without the flyback diode.
Offline alsetalokin4017
« Reply #14 on: September 20, 2015, 10:02:07 pm »
http://www.utsource.net/ic-datasheet/TPIC2701N-786242.html
I've ordered from UTSource several times and have always been happy. Generally takes 10-12 days from ordering to delivery in my mailbox in Texas.
Offline tom66
« Reply #15 on: September 20, 2015, 10:10:53 pm »
Only 100mA?
Only if it's across the motor. The diode in most MOSFETs isn't.
You can only get away with this if the breakdown energy rating is << the energy stored in the inductor (0.5LI^2)
« Reply #16 on: September 21, 2015, 01:24:05 am »
This is a discontinued and non SMD IC, right?
Offline OlegH_ua
  • Country: ua
    • Consense, Ltd
« Reply #17 on: September 11, 2018, 11:30:13 am »
I had the same question and I've found good chip for ULN2003 substitution:
https://www.ti.com/product/TPL7407L
price is about $0.35
« Last Edit: September 11, 2018, 11:47:05 am by OlegH_ua »
The following users thanked this post: Zero999, ogden
Offline ogden
  • Country: lv
Offline OlegH_ua
  • Country: ua
    • Consense, Ltd
« Reply #19 on: September 11, 2018, 12:02:20 pm »
Min 8.5V supply :(
COM pin supply voltage usually is equal to load power, so for most cases 8,5V min is normal.
Also from datasheet's paragraph 9:
"Though 8.5 V minimum is recommended for Vcom, the part will still function with a
reduced COM voltage that has a reduced gate drive voltage and a resulting higher Rdson"
« Last Edit: September 11, 2018, 12:04:18 pm by OlegH_ua »
Offline Zero999
  • 0999
« Reply #20 on: September 11, 2018, 12:35:16 pm »
Min 8.5V supply :(
It would be nice if there was a graph of the on resistance vs power supply voltage, on the data sheet.
Offline MasterT
« Reply #21 on: September 11, 2018, 02:50:00 pm »
Toshiba has IC operating as low as 2V: TBD62783APG
Long list sourcing/ sinking types, MIN voltage 2V, 2.5V, 3V, 7V:
https://www.mouser.ca/Toshiba/Semiconductors/Power-Management-ICs/Gate-Drivers/_/N-41fcp?P=1z0zkx4
The following users thanked this post: ogden, OlegH_ua
Offline Evan.Cornell
« Reply #22 on: September 11, 2018, 04:11:11 pm »
Take a look at Toshiba TBD62003A. Similar idea to TI TPL7404L (FETs instead of Darlingtons), but without the 8.5V requirement.
The following users thanked this post: oPossum, ogden, OlegH_ua
Offline JPortici
« Reply #23 on: September 11, 2018, 05:34:32 pm »
Diodes inc make a ULN2003 compatible that uses logic level mosfets, i used it in a project some months ago
The following users thanked this post: OlegH_ua
Offline koendv
« Reply #24 on: April 24, 2019, 10:21:53 am »
tpl7407ldr. Texas Instruments. Plug-in compatible.
« Last Edit: April 24, 2019, 02:45:21 pm by koendv »
