Author Topic: Wiring Harness Tester - Confused about Some Crucial Design Decisons  (Read 5818 times)
Offline PsychedelicBreakfastTopic starter
Hi everyone,
I've discussed various aspects of my project on various forums over the web (Electronics Stackexchange etc.) but I'm sort of stuck on some aspects. I'd ask on Stackexchange, but I felt the topic lent itself more to discussion than to Q/A, hence my post.
I'm designing an electronic wiring harness tester for my employer. I have two CPLDs, one as a designated driving end (all pins are output) and another as an receiving end (all pins are input). The driving end CPLD is programmed to be a Serial In Parallel Out shift register and the receiving end is a Parallel In Serial Out shift register.
Let's assume all the wires in the harness are one-to-one i.e. no junctions. Let's also assume that there are only 8 wires. So, to test the first wire in the harness, the driving end register is loaded with 10000000. The receiving end also sees this and it all ends well. The driving end is then clocked and it reads 01000000. If the receiver also reads this, then that wire is OK. I'm sure you can see how this also works if a wire has a junction.
I should add that the speed of operation is very slow. The receiving end shift register is clocked out at just 62.5kHz. The driving end will, of course, be even slower as the MCU has to wait.
Here's where I've hit a road block:
1) If there is a short circuit between wire 2 and 3, then the output pins connected to pin 2 and 3 will "fight" each as one would force 3.3V (the active pin) and the other would force 0V (the inactive pin). I discussed this on Stackexchange and was given quite an elegant solution - instead of having 0 on the inactive pins, I should tri-state them and use a pull down on the other end.
This made sense to me but then I realized that suppose there's a junction with, say, 50 wires going out. Let's further suppose I have a pull down resistor of 5K. If this is the case (and it's quite common that it is so!), then the a single output pin on the CPLD needs to be output:
50 * 3.3/5000 = 33mA.
Unfortunately, my CPLDs pin are not strong to do so. The max. rating is just 25mA. The obvious solution at this stage is to just increase the resistance to, say, 47K. This will reduce the current to just 50 * 3.3/47K = 3.5mA. But this obviously results in a weaker pull down and I was warned that EMI could end up causing trouble for my circuit. The harness, particularly for trucks, can be quite long! Upto 10 meters in some cases. Do I need to worry about EMI effects if my frequency is just 62.5kHz?
2) I was recommend that instead of a pull down/up, I should add in a transistor. This will pull the current directly from the supply and the not from the pin, so that problem is solved in anycase. But I wish the solution was easy as this - the issue is that the harness can be large as 300 wires in some cases and my circuits needs to be able to test that.
This isn't as difficult to realize as it may seem - I can achieve it by just cascading 3 TQFP-144 CPLDs for the driving end and the same for the receiving end. But if I start putting a MOSFET on every IO trace, its going to make an extremely large board.
3) I do have a solution for this. But I just don't know if its a good solution. Instead of having a large massive PCB to test 300 wires, I should instead have a "main board" which consists of a single MCU, and two CPLDs. This would allow me to check 114 wires. If a bigger circuit is required, we connect a "daughter board" to the "main board".
This PCB would consist of two CPLDs which, when connected to the main board, are cascaded with the other two CPLDs to form a larger shift register. We could extend this approach for how many we desire. But is this a good solution to the problem? It's advantageous when it comes to costs. Most of the harnesses are small and can be tested with just the main board. Why get a such a large circuit manufactured when we're only gonna test small harnesses most of the time? And when its required to test a large harness, we can simply cascade the other smaller PCBs.
But I'm wondering if I'm "over-engineering" the problem here. If I don't need the transistor and can get away with a weaker pull up, then I feel thats a better approach. I can even reduce the frequency of the operation even further. It's not the limiting factor. I'm  just after a reliable design (aren't we all?!) which is not influenced by EMI factors or other such issues.
Thank you for reading this massive post. I realize how long it is but felt  I should give you guys full information on the subject. Also, I know I should probably have this discussion with my colleagues but unfortunately I'm the lone electronics engineering at the company :(.
Offline Neilm
Re: Wiring Harness Tester - Confused about Some Crucial Design Decisons
« Reply #1 on: October 27, 2011, 05:55:44 pm »
To decide if EMI would be a problem, you would have to consult the relevant standard. I don't know if there would be one especially for this sort of application otherwise IEC61326( Electrical equipment for measurement, control and laboratory use - EMC requirements) would be worth consulting.  While 62kHz might not be very fast, if the edges rise quickly you might have a problem. As it isn't very fast, you could add some capacitance to the line so it only changes slowly.
I would agree with the ideas from Stackexchange for doing the actual testing, although I would probably have them all pulled up then pull each one down using a transistor That way only one resistor would be conducting at a time and so less power would be used. You don't need a MOSFET for this just an ordinary transistor (BC817 for instance) would do. They are available in SOT23 form so are quite small.
One thing I would not do is directly put the CPLD onto the output, there exists the possibility that an ESD spike could damage the chip which would mean the whole device needs replacing. The transistor would would be a lot easier to fix and probably more robust. (This depends on the CPLD you are using, but I have had problems due to ESD in the past).
Neil
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code https://ts.la/neil53539
Offline Simon
  • Global Moderator
    • Simon's Electronics
« Reply #2 on: October 27, 2011, 06:13:01 pm »
I think you just need to bite the bullet and put as many I/O as you require without over designing. if the wire has junctions then you have 1 input and n outputs as each needs testing separately, I'm not sure why you are so concerned about pull ups/downs, why not just put a 1 or 0 on the wire straight from the mcu and let the other mcu or other device at the other end read that and let you know the result ? as for speed, well I don't know how complex the looms are but surely if you are afraid of EMI which should not be an isssue as you test one wire at a time then just reduce the frequency or rather the speed at which the wires are tested, even 1 second should be long enough to do a full test without high frequencies travelling down the wire.
« Reply #3 on: October 27, 2011, 06:31:33 pm »
I should've added that transmitting EMI isn't a concern. The device isn't going to be sold on the market or anything. I'm concerned about "false negative" because this device is going to be used on wiring harnesses the company manufactures for quality assurance purposes.
This is a great point. I understand that a transistor should be between the CPLD and the harness for protection but I'm having trouble visualizing how the transistor ought to be connected. Are you suggesting that I connect the harness onto the collector - with a resistor between Vcc and the collector pin? The output of the CPLD is then connected to the base of the transistor. The other end(s) of the harness is then directly connecting to the input pin of the receiving CPLD - and I assume that there is less chance of ESD damage at this end because of the high input impedance of an input pin. Am I correct so far?
Thank you for an excellent response, by the way. I really appreciate it.
« Reply #4 on: October 27, 2011, 06:34:35 pm »
There is a problem with this approach. Think of the devices as simple 8 bit shift registers. Let's assume the wiring harness only consists of one-to-one wiring. When the Parallel Out shift register outputs 01000000 and receiving end will see 01000000. If however, there is a short between pin 1 and 2, the receiving end will see 11000000. This isn't a problem so far, but think of what is happening at the output pin 1 and pin 2. Pin 1 is trying to force 0V while pin 2 is trying to force 3.3V - I don't think this is a good approach. By using tri-state outputs with pull up/down resistors, I don't have to worry about this problem.
Offline jimmc
« Reply #5 on: October 27, 2011, 07:37:55 pm »
Hang on,
I don't know what cable you're using but a reasonable guestimate would be that the capacity between a given core and the rest would be in the order of 100pf/ft.
(see https://edeskv2.belden.com/Products/index.cfm?event=printPrev&pnum=22603&ut=english for a random example)
So for a 10mtr cable( ~33ft) the capacity would be about 3.3nF.
With a 47k pulldown resistor this gives a time constant of 3.3E-9*47E3 ~ 155uS or 10 times the clock period (1/62.5kHz)!
Not trivial to design robust drivers /receivers; are there nasties such as arc welders in the vicinity?
Induced voltages could be high!
Jim
« Reply #6 on: October 27, 2011, 08:30:12 pm »
Hang on,
Jim
No, there are no arc-welders or anything of that nature nearby. The only machines sharing the floor would be crimping machines.
I didn't quite understand your bit about the timing constant. How does that affect my frequency of operation?
Online ejeffrey
« Reply #7 on: October 27, 2011, 09:45:04 pm »
I a junction with 50 inputs tied together a valid device?  That is, do you need to be able to test a device with a 50 contact junction and say 'yes, this works properly', or is it sufficient to merely detect that as a failure as long as the tester is not damaged?  Is this a pass/fail against known references or do you really need to map an arbitrary cable?  The design can be somewhat simplified if you can make a few assumptions.
Also, I wouldn't worry about external EMI.  I would feel free to make the pull-down resistors 100 k or even 330 kohm.  Then the driver shouldn't have any problem sourcing enough current to pull 50 inputs high.  The only thing you have to do is estimate or measure the capacitance and make sure you give it enough settling time.  Basically, you have to consider that the short-circuit current of the driver is charging the cable capacitance.  Coaxial cable or shielded wires are around 100 picofarads/meter.  In the worst case scenario where you have 50 individually shielded wires, you will be driving 1 nf/meter.  For a 10 meter cable, it will take 6.6 microseconds to charge that capacitance to 3.3 volts.  That limits the frequency you can operate to less than 150 kHz or so -- but only if you have 50 individually shielded wires all connected to a common signal.
« Reply #8 on: October 27, 2011, 10:01:21 pm »
It's not only important to verify if the contact is working properly but it's also required to report where a fault is, if there is one. The aim is to first map the harness by using a Reference Harness. The reference harness will be ensured that its OK. Once that's connected, the system will load a "walking one" test vector and note down the resultant output. So, for instance, if 10000000 results in 10100011 we know that wire 1 results in a junction that connects to pin 1,3,7 and 8. It will then shift the test vector towards right i.e. it's now 01000000. If the system reads 00001000, we know that there is only a one-to-one relationship between the wire that's connected at pin 2 of the driving end and it ends up connecting to pin 5 at the receiving end.
Note that, we setup jigs that ensure that a harness is always connected in the same way to the system. The same wires will connect to the same pins, always. The plugs and the way the jig is laid out ensures this.
In essence, by mapping the test vectors and their outputs, the system can pinpoint where a short circuit or an open circuit occurs. The only requirement is that it needs to "map" the harness at first which is easily done when supplied with a harness that's known to be working properly. I hope that answers your question. Please let me know if it doesn't.
This is a great point. As mentioned, I shift out the receiving end shift register at 62.5kHz. Assuming I shift out 300 bits, this takes about 4.8ms. This shift register will be read out every time the test vector at the driving end is pulsed - so, assuming the processing time by the MCU is negligible I will be sending a pulse to the driving end every 4.8ms or at 238Hz - very very slow. I feel this should give the wire more than enough time to charge up.
I can also add in a small delay between when I pulse the test vector and when I read out the receiving end shift register.
« Last Edit: October 27, 2011, 10:09:45 pm by PsychedelicBreakfast »
Offline Rufus
« Reply #9 on: October 27, 2011, 10:54:44 pm »
Why doesn't your employer just buy one? About $500 for a low end 64 point tester.
« Reply #10 on: October 28, 2011, 03:33:45 am »
Because I live in a 3rd world country with large import customs.
