Hey there
the following circuit is a pulse missing detector, I want to use a RMT signal output from a ESP32 GPIO to feed the input of this circuit, thereafter, when the microcontroller is stopped working the circuit send a low voltage level to EN pin and so the microcontroller got reset, but the issue here is while the boot up, the voltage level shall be high so the boot happens but the output of the circuit without input signal is always down and stop micro from boot up, is there any solution to it?
