Would like to connect a transformer directly to the 50\$\Omega\$ output of a generator, to step-up the voltage in order to build a curve tracer from an AWG and a DSO in XY mode.
I have 3 small transformers at hand, 2 from former wall wart power supplies, and a 3'rd of an unknown provenience:
- T1: 220Vac/12Vac, 450mA, N ratio=18, Rprimary=1670\$\Omega\$, Rsecondary=5.5\$\Omega\$
- T2: 110Vac/10Vac, 200mA, N ratio=10, Rprimary=570\$\Omega\$, Rsecondary=4.7\$\Omega\$
- T3: ?Vac/?Vac, ?mA, N ratio=30, Rprimary=257\$\Omega\$, Rsecondary=1.0\$\Omega\$
The AC voltages that the AWG (a Rigol DG4202) can generate on a 50\$\Omega\$ resistive load is max 10Vpp between 0-20MHz. Would probably never use more than 1kHz anyway for curve tracing. However, max 10Vpp (as in +/-5V) is too little to test certain components with a curve tracer (e.g. for a more than 5V Zener diode, or to see the breakdown voltage in transistors, etc), so I want to increase the max AC available with a step-up transformer.
I'm tempted to use the transformer with the biggest transforming ratio, 30, though that would mean the 50\$\Omega\$ output impedance from the AWG (neglecting the resistance of the transformer windings) will be seen as a 30*30*50\$\Omega\$=45k\$\Omega\$ on the other side of the transformer.
45k\$\Omega\$ in series with the DUT seems pretty big to me, and I've never had a proper curve tracer, so I don't know if I should go for a x30 step-up voltage (+/-150V max) at 45k\$\Omega\$ output impedance, or for a x10 transformer (+/-50V) at an output impedance of 5k.
What other aspects to consider for a curve tracer?
Which transformer to choose?
