Author Topic: cheap precise current sources?  (Read 2066 times)
Online coppercone2Topic starter
« on: October 10, 2018, 07:45:18 pm »
I don't normally use this word, but if you need a cheap current source, what are good parts?
Normally I would use a precise Vref and a op-amp to make a HCP... but how about pure current sources 100uA-1mA... are there any good IC's or weird solutions I missed? Something like a REF200. For biasing transducers etc.
I also looked at current output DACs before I think, but the best one was still pretty crappy compared to a discrete solution (meant for fan control or something).
Are there any amazing one chip solutions for this? I do like the REF200, it makes sense when you need 2 rtd or something since its pretty stable. But can you go cheaper?
« Last Edit: October 10, 2018, 07:47:17 pm by coppercone2 »
Offline In Vacuo Veritas
  • I like vacuum tubes. Electrons exist, holes don't.
Re: cheap precise current sources?
« Reply #1 on: October 10, 2018, 07:48:07 pm »
How about a NUMBER for what you consider cheap? Are we supposed to guess your budget?
AD5749ACPZ
« Reply #2 on: October 10, 2018, 08:00:16 pm »
hard to say i wanna see some parts to see if anything catches my attention with price/performance ratio
just brain storming
Online SiliconWizard
« Reply #3 on: October 10, 2018, 08:08:22 pm »
I like the REF200. I reckon it probably doesn't qualify as cheap though?
Online IanJ
  • Country: scotland
  • Full time EE & Youtuber
    • IanJohnston.com
« Reply #4 on: October 10, 2018, 08:15:07 pm »
Brainstormin here also........
I played with a test version of my PDVS2 and gave it an extra banana socket and a 0-2mA output (as well as the 0-10Vdc mode). If I remember correctly it's load range was something like 0 to 5kohm. It is based around the INA326 amp for the final current output drive which works pretty good.
I never put it into production as it put the BOM up more than I wanted it to........maybe I'l re-visit it eventually.
Ian.
« Last Edit: October 10, 2018, 08:23:37 pm by IanJ »
Ian Johnston - Original designer of the PDVS2mini || Author of the free WinGPIB app.
Website - www.ianjohnston.com
YT Channel (electronics repairs & projects): www.youtube.com/user/IanScottJohnston, Twitter (X): https://twitter.com/IanSJohnston
Offline The Soulman
  • The sky is the limit!
« Reply #5 on: October 10, 2018, 08:44:16 pm »
lm317 and one resistor?  aprox. 30ct in small quantity's.
Performance may vary but I have had good luck with mine, used in various projects/applications.
About max 0,02% deviation over a couple years time, with cheap components.  :-+
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #6 on: October 11, 2018, 12:42:10 am »
2 transistors and a resistor?
« Reply #7 on: October 11, 2018, 01:02:06 am »
the ref200 is 25ppm/c
« Reply #8 on: October 11, 2018, 02:01:48 am »
Another IC to consider is the TL431 which is much cheaper than the REF200. You can build constant current sources/sinks around those with just a couple resistors and a transistor. Overall cost < $1.
I doubt you'll quite get the performance of a REF200 but it's cheap.
The following users thanked this post: joseph nicholas
Offline David Hess
  • DavidH
« Reply #9 on: October 11, 2018, 03:54:41 am »
The LM334 produces an adjustable precision current which is proportional to absolute temperature but can be temperature compensated with an external diode.
The best way to build a precision floating current source is with an operational amplifier and precision reference.  Check out the LM10 datasheet for an example; the same configuration is used for operational amplifier 4 to 20 milliamp transmitters.
« Last Edit: October 11, 2018, 04:04:33 am by David Hess »
