Author Topic: Anyone know something about this display?  (Read 2948 times)
Offline nardevTopic starter
  • Country: ba
« on: February 28, 2018, 09:59:19 am »
This is some old "picture frame" and it looks like the display is functioning so since i have few of those, i would like to use only the display in some other project. However, i don't know anything about this display nor did i ever reverse engineer it.
So, just in case, if you have any tips how should i try to investigate this.. or if anyone know how to find some tech docs about this display i would be grateful
thnx
Offline plazma
    • Homepage
Re: Anyone know something about this display?
« Reply #1 on: February 28, 2018, 10:02:30 am »
Google those codes on the sticker. Manufacturer seems to be Tianma.
  • Country: ba
« Reply #2 on: February 28, 2018, 10:09:10 am »
Ou, i tried it LOOOOOooong time ago didn't find anything.. will try again.. thnx
p.s. looks like there is some tech data now... Just wondering what can drive it...
https://docs.toradex.com/103195-tianma-tm070rbh10-datasheet.pdf
« Last Edit: February 28, 2018, 10:22:32 am by nardev »
Offline Ordinaryman1971
« Reply #3 on: February 28, 2018, 02:59:49 pm »
I was wondering if they could be used to feed vga signal to it and use it as a display... for something.
The following users thanked this post: nardev
  • Country: ba
« Reply #4 on: February 28, 2018, 06:01:35 pm »
Well, would be very happy if beaglebone/rpi was possible to show something :D has samenumber of pins  as  rpi touch screen.. however i didn't check the pins yet...
Offline ajb
« Reply #5 on: February 28, 2018, 06:49:54 pm »
That datasheet shows a 50 pin connection with 24-bit parallel RGB interface.  The flex out of your particular module only has 26 pins, so that can't be it.  I think this is the datasheet you want: http://www.beyondinfinite.com/lcd/Library/Tianma/TM070UDH01-V1.4.pdf
  • Country: ba
« Reply #6 on: February 28, 2018, 07:18:15 pm »
Thank you [emoji16]
Sent from my LG-D858HK using Tapatalk
Offline amyk
« Reply #7 on: March 01, 2018, 01:47:49 am »
Notice the TM070UDH01 datasheet has in its revision history "Modify the Module Name from TS070OAAAD01-00"... whereas you have apparently a TS070OAAAD02-00, and that leads us to
http://www.beyondinfinite.com/lcd/Library/Tianma/TM070UDH02-V1.4.pdf
I guess everyone who thinks that O is actually the number 0, is rightly confused. There's plenty of search results for TS0700AAAD02, mostly sellers, but using the letter O will give you the right results.
