Hello everybody. I have designed a circuit that is supposed to turn on an led after a certain amount of time. The circuit as I have drawn it and excuse the poor handwriting, works exactly like I thought it would. I was trying to think of improvements on it and to reduce part count. So I took the output of my flip flop and bypassed it straight to the nand gate input or point B in the drawing, bypassing the hex inverters. Curiously enough, the circuit starts misbehaving and the output will immediately turn on as soon as power is applied. I noticed that when power is applied the 555 monostable will actually have a "hump" and this hump lasts for around 6ms and reaches a peak voltage of 1.3V but if you look at the circuit it shouldn't matter because the flip flop output is a 0, so the nand gate returns a logic 1, which then is inverted back into a 0 and the LED is off. Does anybody have any ideas on why bypassing those inverters causes it to misbehave?
