Comments about my interpretaion of posts by Copper and Bean.
A single bevel butt is a mainstream structural joint probably referenced in all the structural welding standards -reliable because it is done from only one side, and because there is less step in the cross section.
A lap joint has about 2 * step in area at the weld which becomes a stress concentration in bending and tension.
The term " Brazing" defined by AWS is fuzzy and wide, extending to the wicked/sweated plumbing joints Copper has done, to a joint made with filler rod.
"The Oxy Acetylene Handbook" by Linde differentiates "brazing" as a thin film of filler drawn into a joint.
Then "bronze welding" as having joint design the same as if it would be fusion welded, but the parent is not melted. After "tinning" (now called alloying), the joint is proceeds with filler rod and "the results are fully compatible to those obtained through fusion welding"
Chapter 19 covers "Principles of Bronze Welding"
I would classify the Harris solder wire 1 ounce and flux as linked by CopperCone, as "brazing" and the Alumiweld which comes in 3mm rods , half pound tubes,as being more like "bronze welding".
The big difference is that Alumiweld has almost no plastic or "mush" zone between solid and liquid.
And gas torch, due to the high thermal conductivity of Aluminum, does not allow a close control of the melt that TIG can do.
Therefore gas torch joints can not be made close together. So many of the fusion weld joints shown in the posts become difficult, unreliable and impossible, as I have experienced and I think also 2 others on this thread have experienced.
