Hi WaveyDipole,
A happy AR488 user here. Many thanks for all the hard work you put into AR488!
A suggestion for a small improvement:
Several times the subject of problems with the ++ver string came up, as discussed here:
https://www.eevblog.com/forum/projects/ar488-arduino-based-gpib-adapter/msg4512557/#msg4512557The problem is that KE5FX requires 'Version 6' and EZGPIB requires 'GPIB-USB' in the version string.
So far the solution was that KE5FX and EZGPIB users had to change the version string with ++id verstr and ++savecfg.
I looked at the version string of my Fenrir GPIB-USB adapter (a Chinese Prologix clone): “Fenrir GPIB-USB 1.0 (Prologix version 6.0 compatible)"
It is clever that all required character sequences are present in the string.
Would it be a good idea to do the same thing for AR488? And make the default ++ver string something like: "
AR488 GPIB controller, ver. 0.51.18, 26/02/2023 (Prologix version 6.0 GPIB-USB compatible)".
Putting the character sequences required by KE5FX and EZGPIB into the default version string would save new users a lot of searching before finding the ++id verstr solution.
Regards, Gertjan.
