Also check your case temps and BIOS settings. The highest recommended operating temperature for a 3930k is 67C. Mine runs in the low 60s at full load during the summer.
You can't use a stock cooler on a 3930k because there isn't one. (There is a reference design cooler, but that's not exactly a "stock cooler".) Also try using i7z to get detailed stats.
