Author Topic: Restoring an Old Oscilloscope  (Read 9335 times)
Offline tayexdrumsTopic starter
« on: April 04, 2011, 04:36:05 am »
I just got an old 5 MHz analog oscilloscope a few days ago, but unfortunately it doesn't quite work right. All I get is this when I turn it on....
I want to restore it to working condition, but I don't really know where to start. I know that it is a kit from the 1970s from DeVry School of Technology. I have all of the manuals, schematics, books, etc. Like I said, I really want to restore this thing to working condition. Here are more pictures of the scope........
« Last Edit: April 04, 2011, 04:37:53 am by tayexdrums »
Offline PeterG
Re: Restoring an Old Oscilloscope
« Reply #1 on: April 04, 2011, 05:16:34 am »
I would start by looking at the Horizontal timebase and work from there.
Regards
Testing one two three...
Offline insurgent
« Reply #2 on: April 04, 2011, 05:27:02 am »
In all the pics the vertical input is set to "calibrate". I'd flip that up and set all the variable controls to the halfway mark and see what you get.
Offline saturation
  • Doveryai, no proveryai
    • NIST
« Reply #3 on: April 04, 2011, 05:26:08 pm »
Concur.  There doesnt' seem to be any horizontal sweep.  After turning off the calibrator, which could be a 1Vpp square wave, you should have a single dot, suggesting the horizontal sweep is dead.  Try a 1-10Vdc and just touch it on the horizontal inputs and it should cause it to jerk left or right, this might mean the amp is ok but just the oscillator is dead.
I remember a scope similar to that in old trade catalogs when I was a kid; it was a kit for DIY.
Regards
« Last Edit: April 04, 2011, 05:28:41 pm by saturation »
Best Wishes,
 Saturation
Offline Frangible
  • Contraptioneer
« Reply #4 on: April 05, 2011, 03:43:31 am »
That's actually a Heathkit re-badged as Bell&Howell.  Most of the semiconductors in there will be marked with Heath's own part numbers.  Fear not, there are plenty of sites that contain cross references between Heath part numbers and standard parts.
« Reply #5 on: April 05, 2011, 02:04:43 pm »
okay, So I should check the horizontal timebase circuit board components? Then , if I find any components that are bad I can find replacement parts by cross referencing them?
Offline tecman
« Reply #6 on: April 05, 2011, 06:38:35 pm »
With that news, look through here:  http://www.vintage-radio.info/heathkit/  to find schematics and other docs on Heathkit products.
paul
Offline slburris
« Reply #7 on: April 05, 2011, 09:01:30 pm »
It's a Heathkit 10-102 scope.  I checked a few of the schematic archives
and couldn't find that one.  Did you get any documentation with the scope?
Scott
Offline tecman
« Reply #8 on: April 05, 2011, 09:40:53 pm »
Scott
If that is the correct model, it is on the link I provided.
paul
Offline slburris
« Reply #9 on: April 05, 2011, 09:55:07 pm »
Bah, now that I study the pics more closely, it doesn't have
exactly the same faceplate.
I thought Bell & Howell changed just the labeling but otherwise
made no changes to the design?
The 102 has specs that seem to match, and it does have a schematic
on the vintage radio site.
Scott
