Author Topic: [Solved] Are balanced diode gates still used in practise?  (Read 352 times)
Offline ballsystemlordTopic starter
  • Student
« on: December 31, 2024, 02:12:43 pm »
Hello,
Recently I was discussing how to measure the settling time of op-amps and it was suggested to follow Mr. Jim Williams method via these PDFs:
https://www.eevblog.com/forum/testgear/what-is-the-derating-of-a-1mohm-oscilloscope-input/?action=dlattach;attach=2472593
https://www.eevblog.com/forum/testgear/what-is-the-derating-of-a-1mohm-oscilloscope-input/?action=dlattach;attach=2472595
Mr Williams notes that a diode array will work well to produce a nice flat topped wave. The problem is that his part number is obsolete and, if you look on fleabay, quite expensive.
The substitute part would be a set of 4 independent, matched, schottky diodes. Searching through digikey, mouser, farnell, and eliminating incorrect results (and non-ROHS parts), I found that only parts under the UC3611 name were of the configuration I would need.
So with only one part number being active, the question comes up, are balanced diode gates still used in practice, or has some other design replaced them?
Thanks!
« Last Edit: December 31, 2024, 02:25:58 pm by ballsystemlord »
Offline iMo
  • Country: va
Re: Are balanced diode gates still used in practise?
« Reply #1 on: December 31, 2024, 02:18:41 pm »
You may use the 4x cheapo 1N5711 instead of the HP5082-2810 in the bridge there (almost the same diodes afaik).
PS:
« Last Edit: December 31, 2024, 02:25:52 pm by iMo »
  • Student
Re: [Solved] Are balanced diode gates still used in practise?
« Reply #2 on: December 31, 2024, 02:27:11 pm »
It suddenly occurred to me that the diodes would be in the bridge rectifier section of the various websites. I was looking in the diode array section. Ooops.
Thanks guys.
  • Student
« Reply #3 on: December 31, 2024, 02:28:06 pm »
PS:
As mentioned above, they have to be matched. AFAIK, that means either I have to screen them or buy a 4 array configuration of them.
Offline electron_plumber
« Reply #4 on: December 31, 2024, 04:34:31 pm »
If you find any app notes on best practices, let us know. I was recently reading about them here and may try them out in a gated integrator board soon.
Most resources I've found are from the 60's and 70's days of analog computing (e.g. attached).
« Last Edit: December 31, 2024, 04:41:16 pm by electron_plumber »
The following users thanked this post: ballsystemlord
