Author Topic: POE adapter performance  (Read 1024 times)
Online IconicPCBTopic starter
« on: August 20, 2017, 11:29:01 pm »
I have been asked to to asses "quality" of a POE adapter consisting of some transient suppression circuitry ( gas arrester and solid state suppression TVS diodes).
I understand insertion loss and cross coupling are likely to be an issue.
What do the tests consist of?
Is there a single test that would offer an insight into how the adapter willperform?
Is it possible to use a loop through test ( using two NICs) and perhaps measure BER ?
Looking forward to an education...
Re: POE adapter performance
« Reply #1 on: August 21, 2017, 09:50:30 pm »
bump?
Offline nctnico
« Reply #2 on: August 21, 2017, 09:55:13 pm »
I'd use a network analyser to measure the impedance versus frequency. Up to 200MHz is more than enough for 100Mbit ethernet.
Offline drussell
  • Hardcore Geek
« Reply #3 on: August 22, 2017, 03:21:41 am »
Sure!  Put some in operation at your organization for a few years and see what transpires!   ;)
You need to supply some better metrics as to what constitutes "performance"...
Will it supply some voltage to the device?  Probably...
Will it interfere with data communications on the wire?  I certainly hope not!  :)
Could you be more specific?  :)
