Author Topic: Are chinese 10 turn pots any good?  (Read 3267 times)
Offline ivan747Topic starter
« on: August 20, 2017, 10:54:59 pm »
I'm asking this question here in the Projects sub-forum because if I ask on the Metrology forum I'm going to get shot at...
Are those 6 dollar 10 turn pots from China any good? The intended application is retrofitting a DIY lab power supply with them. I'm looking at 10k pots, if that makes any difference.
Cheers,
Ivan
Offline danadak
Re: Are chinese 10 turn pots any good?
« Reply #1 on: August 21, 2017, 12:18:43 am »
On e would expect in datasheet a rotation lifetime spec, if thats your concern.
Regards, Dana.
Offline FlyingHacker
  • You're Doing it Wrong
« Reply #2 on: August 21, 2017, 12:34:44 am »
I have gotten quite a few of the (presumably counterfeit) Bourns ten-turn pots from eBay. About 20% were defective, but always refunded. The others work perfectly. I wouldn't use them for mission critical stuff, but great for personal projects or experiments.
--73
The following users thanked this post: Alex Eisenhut
Offline zeqing
« Reply #3 on: August 21, 2017, 04:43:41 am »
basically try but not rely On. different vendors provide different products.
Offline poorchava
  • Troll Cave Electronics!
« Reply #4 on: August 21, 2017, 06:30:01 am »
Depends on what you want to use them for. For adjusting some bias on a power supply or audio system - ok. For real metrology or critical stuff - not ok.
Offline CopperCone
  • *knock knock*
« Reply #5 on: August 21, 2017, 06:44:50 am »
their tempco is shit and their unstable. treat it like a 1 turn pot. maybe its ok for something you null every time you use, but that would imply your system has like a drift 10x worse then the pot. there are some threads about counterfit pots on eevblog already
i don't know who bochen is trying to fool, perhaps people that don't wear glasses
« Last Edit: August 21, 2017, 06:46:35 am by CopperCone »
Offline owiecc
    • Google scholar profile
Offline bitseeker
« Reply #7 on: August 21, 2017, 11:51:25 pm »
From my experience, they do operate as 10-turn pots. However, the rotational torque required is much higher than a genuine Bourns. I haven't had any long enough to assess their longevity.
« Reply #8 on: August 22, 2017, 12:01:07 am »
They're crap! Killed one dead in a VFO in about a week and it drifted terribly.  It got replaced with the delay sweep pot (bourns 10 turn) nicked out of a dead Tek 465 that is older than me. That's still going 4 years later!
Proper bourns ones aren't cheap new but you get what you pay for.
« Last Edit: August 22, 2017, 12:02:44 am by bd139 »
« Reply #9 on: August 22, 2017, 12:10:09 am »
Maybe mine were genuine. They have been functioning fine, and feel comparable to the genuine ones I have here.  :-//
I use one all the time, as it is to zero the Ohms range on my main giant meter VTVM.
--73
Online edavid
« Reply #10 on: August 22, 2017, 12:20:04 am »
You can buy one for $1.50 and see for yourself: http://www.ebay.com/itm/1pc-3590S-2-103L-10K-Ohm-10-Turn-Rotary-Wire-Wound-Precision-Potentiometer-Pot-/132283650630
BTW, 10 turn pots are very inconvenient and annoying on a lab supply.  It's better to have coarse and fine pots, or an encoder with software acceleration.
« Last Edit: August 22, 2017, 03:08:48 pm by edavid »
Offline drussell
  • Hardcore Geek
« Reply #11 on: August 22, 2017, 03:14:47 am »
Pretty much any time you have to ask "is the cheap Chinese version of X any good", the answer is NO!
(Though, I suppose, there may be exceptions where they may be good enough for most usage...)
Offline Rbastler
  • Wörk Wörk
    • Rbastlers Blog
« Reply #12 on: August 22, 2017, 06:16:27 am »
I used some and from ten, one did brake with out reason to me. So I'd say thats pretty good for the price of 1.5€ a piece. I woudnt use those as replacements in some test gear, but they are certanly ok for your own projects.
Sent from my A0001 using Tapatalk
http://rbastlerblog.jimdo.com/
Gamma spectrometer works. Now some yellow crystals need regenerating and testing.
