Author Topic: Are ferrite beads affected by magnetic field? How?  (Read 2226 times)
Offline ricko_ukTopic starter
« on: March 24, 2020, 09:59:38 pm »
are ferrite beads characteristics affected/changed if a DC or AC magnetic field is placed next to them?
How? Can it be detected/measured?
Many thanks :)
Offline duak
Re: Are ferrite beads affected by magnetic field? How?
« Reply #1 on: March 25, 2020, 03:21:43 am »
You bet they can, but it's not easy unless you've got fairly strong external fields.  If you have a inductor with a medium to high permeability material for a core, measure its inductance both with and without a supermagnet in contact with it.  I just tried this on a 10 uH axial inductor.  One supermagnet reduced the inductance to 1.4 uH and adding another didn't make a difference; somewhat better than I thought it would.  What's happening is that some or all of  the core is getting saturated by the supermagnet and its effective permeabily is reduced, thus reducing the inductance.
This effect is used in Flux gate magnetometers and can be insanely sensitive.
« Last Edit: March 25, 2020, 07:17:52 pm by duak »
The following users thanked this post: exe, ricko_uk
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: March 25, 2020, 01:54:24 pm »
Note that you get the same effect, albeit magnified greatly, due to direct DC bias.  (An external magnet doesn't have a closed path, so they are relatively insensitive that way, but self-bias does of course.)  Ferrite chips aren't good for more than 10s or 100s of mA.  Beads on leads, and cable beads and rings, aren't good for, much more than say 1-10At, depending on aspect ratio and material.
Seven Transistor Labs, LLC
The following users thanked this post: Someone, ricko_uk
Offline ChristofferB
  • Chemistry phd student!
    • My channel:
« Reply #3 on: March 25, 2020, 06:03:02 pm »
IIRC, some ferrite materials will get permanently altered by contact with a magnetic field.
I've heard an old story (maybe early 1960's) about a fairly large danish radio/TV manufacturer who suddenly had a huge surge in malfunctioning products, after they had all their soldering irons replaced with the 'new' Weller ones with magnetic temperature control in the tip, which what traced back to ferrite cores damaged by close contact with soldering iron tips.
--Christoffer //IG:Chromatogiraffery
Check out my scientific instruments diy (GC, HPLC, NMR, etc) Channel: https://www.youtube.com/channel/UCZ8l6SdZuRuoSdze1dIpzAQ
Offline exe
  • self-educated hobbyist
« Reply #4 on: March 25, 2020, 06:36:31 pm »
Thanks, now it all makes sense why this is happening.
The following users thanked this post: ricko_uk
Offline Doctorandus_P
« Reply #5 on: March 25, 2020, 10:45:47 pm »
Fun anecdote:
In Pre-electronic times they used to use transformers as AC switches.
When open, the self inductance of the transformer winding passes very little current.
To close the "switch" a (relatively small) DC current is put through an auxilary winding. The DC current saturates the magnetic field and the inductance of the AC winding is reduced to a small value, and therefore it conducts AC current.
Offline g0fvt
« Reply #6 on: March 27, 2020, 12:26:57 pm »
Hi, a related fun fact is that a magazine here in the UK had a challenge to build a receiver that did not use thermionic devices or semiconductors. (This was for VLF reception). The winning solution used basically an alternator driving a winding in a ferrite core which then behaved as a mixer. I believe it was published in RadCom and the challenge was to receive a CW signal from an RF alternator transmitter. After a search I found some info http://www.wireless.org.uk/mechrx.htm?LMCL=yqb9Uq
« Last Edit: March 27, 2020, 12:33:06 pm by g0fvt »
« Reply #7 on: March 27, 2020, 12:46:58 pm »
g0fvt that's very interesting! Thank you
And thank you all very much for all replies :)
Offline duak
« Reply #8 on: March 27, 2020, 06:01:00 pm »
Thanx kindly, g0fvt.  An excellent example of thinking outside of the box.  I really liked the idea of using a stepper motor as a quadrature generator.
