Author Topic: Need Advice: Current Mode DC Converter, or Voltage Follower into a Resistor  (Read 1457 times)
Offline TheRuler8510Topic starter
  • RF Engineer
Advice Needed:
I want to generate a constant 500 mA that limited to 12V out. I want to use a 6V battery to do it.
Any ideas on the best way? I could use a boost converter and use a voltage follower & MOSFET into a 1 ohm resistor, like Dave did in his current source. Or I could use a current mode DC-DC converter.
Any ideas on a better way? Is there a current mode converter that would do it? Please suggest a chip to do DC-DC conversion for this.
Any suggestions are welcome.
Thanks in advance,
"There are no facts, only interpretations."
--Friederich Nietzsche
