First off, I would never count on any electronic device to keep me safe. Use common sense.
The chip does have some quirky behaviour using I2C at address 0.
The chip does have some design flaws that can be worked around.
The chip is NOT a clear 100% never fail sensor. It has false positives and negatives.
The chip may have sensitivity issues indoors, around metals, and electronic devices.
I am not an RF guy (still working on DC!), but this is not a normal antenna. It works at very low frequencies (500kHz) and uses an inductor as the antenna. Not sure you can really make that omnidirection. Not even sure that it is not, but experimentation seems to indicate that it is.
