I made a probe before that was basically a tiny shielded microphone on a stick, but I am kinda thinking about field rejection and stuff. I used one that's buffered, and put filter caps and ferrite right against it (it is a SMD part), used double shielded cable, 4 wire twisted pair, copper tape and aluminum epoxy to seal it as much as possible, so only the opening of the microphone is not part of the shield (it is about 0.5mm or something).. but I am still concerned. The best solution seems to be to use a mechanical acoustic coupler. It's also not shielded against H-fields. I would need some kind of mu-metal tubes to deal with that I think.
Assuming I want to take actual measurements with instrumentation, whats a good way to measure mechanical waves on a circuit board?
By having the microphone near the part, like I did, I might be coupling fields into the coil so I am picking up electrical activity not real mechanical activity.
By using some kind of waveguide I am having some kind of bandwidth limiting and the microphone is further away from the part being analyzed, so I can possibly pickup other room noises better.I also expect to have some losses.
Whats a good method? What kind of tube should I use, dimensions, and how do I isolate it so its directional? I am completely lost in where to begin with this acoustic design.
