So, Busy running around at 00:15am trying to locate a fault in a 70M long 35 x 4 core SWA Cable (at a local tourist spot).
Some pictures
specifications
https://www.armouredcable.net/35mm-4-core-armoured-cable.htmlCurrent Rating 154A
If above is correct,
Simple to say NOT a RF cable.
It may or may not match the specifications of some local loop telephone cable when using a TDR.
http://www.generalcable.com/getmedia/b9ccd73f-391d-4ef5-b6da-e2f0f29df0e5/G4283If you look at the extremes and what effect they could have you have a better chance of getting something to work.
It is a good idea to know how a circuit work.
Think of why some TDR's use a fast level change.
As stated in previous post a fast pulse will be nothing at a distance. Think of a 1 Hz square wave with very fast rise and fall times. That 1 Hz component forces a change down a very long cable. It shows on oscilloscope. In both cases what is lost is the fast rise and fall times.
With out the fast change you have more length of the cable creating a reflection.
Think of that C-Rual cable at very long lengths, say 10 miles (15.7Km).
You have two conductors separated by an insulator, a Capacitor. But not a simple capacitor, an infinite number of capacitors separated by a small resistance.
Some test equipment used this fact with a very slow charge rate and a meter.
It takes time for that last cap start to change. A short or open will effect the source end after some time. A change in the cable will also effect the meter.
Now think of that signal that is causing all the reflections on the oscilloscope. Due to the cable it becomes an Unknown signal. You can use the results but have no idea of what created the results. The signal changes with distance and reflections created.
Now look at the test setup.
A signal generator connected by cable A to a Tee which is connected to a oscilloscope.
Cable B from the Tee to the cable under test.
The oscilloscope is showing the sum of voltage at the Tee vs time.
The change seen on the oscilloscope is limited by the complete system, the slowest response wins.
To test the above cable you need more then short or open. This is a huge range. If you are looking for future problems you need even more detail that is hidden in the sum voltage at the Tee connector.
So with the above in mind, how do you get better results?
The easy way would be not to test A cable, but test TWO cables. Using the difference between the two cables to highlight the problems in one.
A small change would be using one conductor to test a second conductor.
If you think it through, the easy way would be a positive transition that matched a negative transition with the oscilloscope in A+B. For two cables you could use two positive outputs. With two conductors you would get the most detail with one being inverted with respect of the other.
Cable B has many functions. It serves as a time delay such that an amplifier has time to come out of overload for large signal from signal generator . If you attach a measured length of the cable under test to Cable B before the actual cable under test you get a calibrated time reference if you can see the changes at the connections.
When the fast change wave to create reflections to read becomes a problem, a known wave to create reflections could still function.
A TDR is trying to maximize reflections over a short length of the cable while keeping other reflections to a minimum.
Said a different way, a TDR is trying to identify reflections from a short length of cable while removing all other reflections.
