Author Topic: Low dropout linear voltage regulators  (Read 1329 times)
Offline grifftechTopic starter
    • youtube channel
Offline Kleinstein
Re: Low dropout linear voltage regulators
« Reply #1 on: March 21, 2017, 09:01:26 pm »
The pin-out with TO220 and similar parts depends one which pins is connected to the substrate. This is usually the one in the center to give the best heat flow. This is why essentially all transistors / MOSFETs in TO220 have the collector / source in the center.
    • youtube channel
« Reply #2 on: March 21, 2017, 09:06:21 pm »
this is NOT a MOSFET.
Offline Benta
« Reply #3 on: March 21, 2017, 09:13:56 pm »
Plenty of LDOs with normal pinouts around. LM2940, for instance.
