Author Topic: Attatch 20x4 display without screws  (Read 1106 times)
Offline Jan AudioTopic starter
« on: December 05, 2019, 02:23:09 pm »
Hi, what would be the best way to have a 20x4 display on a front plate without screws ( not soldered on circuit )?
A system for easy attatch, and not moving in panel.
A idea would be nice i can try to print if it works.
Printing with PLA and can not be to thin.
thanks
Offline KMoffett
Re: Attatch 20x4 display without screws
« Reply #1 on: December 05, 2019, 02:33:50 pm »
A photo, or several, would help us help you.
Offline Bud
« Reply #2 on: December 05, 2019, 02:35:44 pm »
Is it to be mounted on the face side or the rear side of the front panel?
Offline honeybadger
  • Country: cz
« Reply #3 on: December 05, 2019, 02:46:10 pm »
...the best way...without screws...
Hot snot  :-DD
« Reply #4 on: December 05, 2019, 03:52:16 pm »
I would like the display be on the inside of the panel sticking out to the front side.
I dont have any fotos to make, i have nothing yet.
Offline andy3055
« Reply #5 on: December 05, 2019, 04:02:11 pm »
Velcro with self adhesive backing.
« Reply #6 on: December 05, 2019, 04:10:22 pm »
There must be some way, i can still use screws when its time.
Not with glue, i want the display to be replacable.
« Reply #7 on: December 05, 2019, 05:39:51 pm »
I dont wanto use glue.
I could make it fit so tight that it wont fall, i used that before.
Now i like to make some clickable or hangable system ( gravity based )
Offline bson
« Reply #8 on: December 05, 2019, 07:57:45 pm »
Stick-on magnets?
Offline andy3055
« Reply #9 on: December 05, 2019, 08:35:12 pm »
Is there a problem using Velcro?
Offline james_s
« Reply #10 on: December 05, 2019, 08:42:20 pm »
Lots of adhesives out there are removable if you need to. I'd probably use silicone caulk, it's strong enough to hold the display firmly but easy enough to cut if you want to get it apart. You want to let it cure in open air before you close the box though as the vapors are slightly corrosive.
