Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
Glow-in-the-dark pot?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Glow-in-the-dark pot? (Read 1620 times)
calzap
Frequent Contributor
Country:
on:
May 12, 2013, 02:27:30 pm »
So, I'm looking for a 3-5 W, 15 K pot, and stumble across a listing on Amazon for a 500 W, 2.2 K wire-wound pot. URL =
http://www.amazon.com/Amico-Resistance-Electrical-Wirewound-Potentiometer/dp/B0087YJ3IQ.
I think it has to be as big as a toaster. Nope, 4.3 cm diameter, 4 cm height, and 1/2 the height is shaft. If my calculations are correct, the "can" has a surface area of 56 sq cm, so that's 9 watts per sq cm. Should get a little hot in most environments. Maybe the spec is off by a couple of decimal places?
Mike in California
Logged
Dave
Super Contributor
Country:
I like to measure things.
Re: Glow-in-the-dark pot?
Reply #1 on:
May 12, 2013, 02:45:50 pm »
I found
this
3W at 55°C, zero at 100°C
The person that wrote that Amazon ad obviously screwed up.
Logged
<fellbuendel> it's arduino, you're not supposed to know anything about what you're doing
<fellbuendel> if you knew, you wouldn't be using it
c4757p
Super Contributor
Country:
adieu
Reply #2 on:
May 12, 2013, 02:52:04 pm »
Yep. And 500W into 2k2 is 1kV! Even at 10% of the range you'd need 330V. You will know when you're looking at a pot that can stand off 1kV...
Logged
No longer active here - try the IRC channel if you just can't be without me
KD0CAC John
Country:
Reply #3 on:
May 12, 2013, 03:06:12 pm »
I thought I remembered glowing in the dark after pot .
Oh sorry , wrong prospective
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
