Hello all,
I am attempting to find a thermostatic switch that is equivalent to:
https://www.sensata.com/sites/default/files/a/sensata-3mp-motor%20protector-datasheet.pdfThis is for a 1700W AC motor, but beyond that I know very little of the motor (it's pulled from a Miele vacuum cleaner so has no faceplate). The thermostatic switch in question has the following contact ratings:
27.5 A @cos 1 / 250Vac / 500 cycles
18 A @cos 0.6 / 250Vac / 1.000 cycles
18 A @cos 0.6 / 120Vac / 15.000 cycle
The motor is ran at 230V, however I just cannot find a thermostatic switch rated as high as this - 27.5A, or even 18A!
I can find a number of thermostatic switches here:
https://uk.rs-online.com/web/c/automation-control-gear/industrial-switches/thermostatic-switchesBut after filtering for a decent contact rating, I find ones such as the following:
https://uk.rs-online.com/web/p/thermostatic-switches/1117739/Which for an inductive load is only rated at
240VAC, 5FLA, 30LRA, 60Hz, Inductive
There must be something I am missing here. Could anybody shed any light on this or if you're feeling rather generous, make a suggestion of a suitable part from the above website?
Thank you!
