Author Topic: Running TINA-TI in Linux Using Wine  (Read 12532 times)
Offline aep9690Topic starter
« on: June 12, 2013, 03:32:03 am »
I want to start off by saying that this may not be the best place to ask this question, but I figure this might be the best place to run into someone who had the same problem.
My work has everyone use Linux or Mac OS, I am using a Linux machine with a slightly modified version of ubuntu.  I am trying to tun TINA-TI through wine, however when I type:
wine Tina90-TIen.exe
Into the command prompt it gives me an error saying that it can't find a module.  I know this is vague but I am at home now and can't get the specific error, I promise I will post the whole thing in detail tomorrow.  The Wine page says that it will run, has anyone else had this problem?
Offline c4757p
  • adieu
Re: Running TINA-TI in Linux Using Wine
« Reply #1 on: June 12, 2013, 03:37:55 am »
Which version of WINE? Is there any other software installed in the WINE directory? And which version of Windows is it set to?
Offline bingo600
« Reply #2 on: June 12, 2013, 10:18:52 am »
Could it be a C or VB Runtime that's missing ?
I usually install VB6 Runtime in Wine
Just install this VB6 Runtime first (via wine) , i did specify C:\windows as installpath
http://support.microsoft.com/kb/290887
But i haven't tried TINA , just LTSPICE , ans that's ok
/Bingo
« Reply #3 on: June 12, 2013, 04:52:31 pm »
So the specific error that I am getting when I run the install file from wine in the command prompt is this:
fixme:actctx:parse_depend_manifests Could not find dependent assembly L"Microsoft.Windows.Common-Controls" (6.0.0.0)
fixme:storage:create_storagefile Storage share mode not implemented.
p11-kit: couldn't load module: /usr/lib/i386-linux-gnu/pkcs11/gnome-keyring-pkcs11.so: /usr/lib/i386-linux-gnu/pkcs11/gnome-keyring-pkcs11.so: cannot open shared object file: No such file or directory
After that an error window pops up, I attached a screen capture of it.
I am using the most recent version of WINE, and I had installed nothing else with WINE at that time.  I did however go ahead and install LTspice, which works fine.  I will try installing the VB6 runtime and see if that fixes it.
« Reply #4 on: June 12, 2013, 04:56:50 pm »
I installed VB6 to C:\windows and tried again and got the same error.
Offline c4757p
  • adieu
« Reply #5 on: June 12, 2013, 05:07:37 pm »
I'll mess with it a bit later to check, but in the meantime, try installing the common controls library:
wget http://winetricks.org/winetricks
sh winetricks comctl32 comctl32ocx
Not sure if that's included with the VB6 runtime or not.
Offline c4757p
  • adieu
« Reply #6 on: June 12, 2013, 05:12:48 pm »
Er... what version of WINE is the "latest"? The latest stable? Latest development? Latest in the Ubuntu repo? What's the output of "wine --version"? Because I just installed it in a clean WINEPREFIX under Wine 1.4.1/Debian 7.0 x86_64 and it works perfectly as far as I can tell.
Offline bingo600
« Reply #7 on: June 12, 2013, 05:47:42 pm »
« Reply #8 on: June 12, 2013, 06:29:16 pm »
I am using Wine version 1.4.
I ran the commands provided by c4757p and I am still getting the same error.
Offline nctnico
« Reply #9 on: June 13, 2013, 01:29:24 am »
The best thing to do is install Windows XP in a virtual machine. Virtual box (free!) works like a charm. I tried Wine as well as a generic Windows replacement but it just isn't up to the job.
« Reply #10 on: June 13, 2013, 05:00:44 am »
I'll try virtualbox on Friday
Offline bingo600
« Reply #11 on: June 13, 2013, 09:47:21 am »
I'm quite sure the cure for the listed error was shown in the url i posted above
But then again a real XP in a Vbox engine is hard to beat.
I just prefer to use wine if possible.
/Bingo
Offline colotron
  • Country: ar
« Reply #12 on: June 15, 2013, 07:53:23 pm »
I've installed a couple months ago, to never use it  :palm:
But its running.
I'm using Ubuntu 10.04.2 64 bits with wine1.4, winetricks 20120308, and the following libraries
$ winetricks list-installed
comctl32
corefonts
dotnet20
mdac27
mdac28
mfc42
msvcirt
msxml3
vc2005express
vcrun6sp6
vcrun6
I have however some issue: the window dissapears of the ctrl-tab list when minimized, I restore by right-clicking on the window list -> minimize, and again ->maximize/un-minimize
Tell me if there is any other information you need.
The TINA version is:
Version 9.3.50.40 SF-TI
« Last Edit: June 15, 2013, 08:01:16 pm by colotron »
