Hi all!
So I'm doing the old ATX power supply conversion project - making a lab bench power supply from an old ATX supply. My project has gone pretty well so far, last night I turned it on and got the correct voltages everywhere
My problem is this;
At the moment I have a 10Ohm 10W Power Resistor going from 5V to GND to 'stabilise the voltages' (several guides I read suggested this). This resistor is heating up (my temperature probe reads up to about 50 degrees Celsius and increasing fast), before I turn it off. The fan doesn't seem to be able to cool the resistor down (the resistor is zip-tied to one of the heat sinks, so the fan turns on when the heat sink gets to about 40 degC).
Should I change the resistor to go from 3.3V to GND? Or should I just remove it all together?
Photo attached for reference;
