Author Topic: HF Conducted emissions - Spectrum analyzer  (Read 687 times)
Offline mattkoTopic starter
« on: February 14, 2019, 08:53:58 am »
Hello,
I'm doing pre compliance for conducted emissions and the measurements at high frequencies (80 MHz - 108 MHz) are lower, comparing to measurements done at a certified laboratory. From your experience, which things affect measurements at these frequencies?
I tried the spectrum analyzer at the certified laboratory and it performed the same as their SA, so the problem should be in our test setup.
I'm using a 12 V battery, 5uH LISN, short cables from LISN to DUT, GND plane under DUT (same distance to DUT), R&S SA
Any ideas would be welcome!
