That's a good choice. There are no reasons not to use it.
One could object that a loudspeaker has a complex impedance (resistive, inductive and even capacitive components) and it's also nonlinear (inductance, phase varying with frequency, etc).
However, using a resistor it's an accepted practice. In any case, the amplifier characteristics and performances are usually specified using a resistive load.
Also, a quick comment on using resistors that will have to dissipate a lot of power: the temperature coefficient is very important since it could modify the resistance for different output powers. However, in your case, the tempco is only 50ppm, which is perfectly usable.
Cheers
