Author Topic: uCurrent multimeter 2mm tip compatible mod  (Read 2989 times)
Offline nukieTopic starter
« on: June 28, 2012, 05:04:05 am »
Hi all,
This is my humble contribution to the eevblog community.
I only use my multimeter leads with the uCurrent. I constantly find myself getting frustrated with the loose multimeter leads falling off the holes of the banana sockets so I wanted something that is secure mechanically and electrically. So I rummaged through my parts and found these 2mm sockets and they pop right into the existing holes. Most multimeter tips are 2mm so this should be pretty good and hopefully they don't wear out the surface of the tips quickly.
Just remove the existing banana sockets and replace with these 2mm sockets, then solder a wire to the pcb trace. This mod saved my day!
You can find thenm very cheap at electronic parts store. Look for "2mm sockets".
« Last Edit: June 28, 2012, 05:07:04 am by nukie »
Offline EEVblog
Re: uCurrent multimeter 2mm tip compatible mod
« Reply #1 on: June 28, 2012, 06:55:51 am »
Yes, good solution for direct probes.
Dave.
« Reply #2 on: June 28, 2012, 03:35:13 pm »
Very good idea, most will have the standard multimeter leads almost permanently attached to the meter.
Offline robrenz
  • Real Machinist, Wannabe EE
« Reply #3 on: June 28, 2012, 04:59:02 pm »
No mod necessary with these.
Pomona Pin Jack to Banana Plug; Brass (Plug); Beryllium Copper; 2500 WVDC
Model 1809-0  is black
Model 1809-2  is red
PDF shows dimensions
« Last Edit: June 28, 2012, 05:02:31 pm by robrenz »
Offline BravoV
  • +++ ATH1
« Reply #4 on: June 29, 2012, 06:48:58 am »
Cool idea, thanks.
Sharing my different approaches when using my ucurrent.
1st pic, using cheap banana connectors for audio speaker since it has the crimp to hold the probe's tips firmly & steady.
2nd, Banana to BNC connector when using logger or scope.
« Last Edit: June 29, 2012, 07:09:44 am by BravoV »
