Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
Audio Amplifier Application Schematic
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Audio Amplifier Application Schematic (Read 1164 times)
eerocketman
Contributor
Country:
on:
April 15, 2019, 01:23:38 am »
Hi Everyone,
I am making a bluetooth speaker using the the LM2976 (
http://www.ti.com/lit/ds/symlink/lm2876.pdf
). the typical aplication schematic is pretty straight forward except for a BJT connected to the power leads of the IC. Could someone explain what the purpose of the BJT is? I have highlighted the component in question on the attached image.
Thanks!!
Logged
Circlotron
Super Contributor
Country:
Re: Audio Amplifier Application Schematic
Reply #1 on:
April 15, 2019, 01:27:35 am »
With split pos and neg supply rails pin 7 is normally grounded i.e. halfway between pos and neg. With a single supply rail setup like in this diagram the BJT supplies pin 7 with approx half rail voltage.
Logged
eerocketman
eerocketman
Contributor
Country:
Reply #2 on:
April 15, 2019, 01:32:30 am »
Got it, thank you!
Logged
coromonadalix
Super Contributor
Country:
Reply #3 on:
April 15, 2019, 01:32:53 am »
the 2n3904 is not an bjt, its an npn transistor
Logged
eerocketman
Contributor
Country:
Reply #4 on:
April 15, 2019, 01:35:30 am »
Could you elaborate on the difference? I thought NPN transistors were BJTs.
Logged
coromonadalix
Super Contributor
Country:
Reply #5 on:
April 15, 2019, 02:46:12 am »
sorry its bipolar junction transistor indeed my bad
mixed with an ujt loll
Logged
Audioguru
Super Contributor
Country:
Reply #6 on:
April 15, 2019, 03:27:26 pm »
What speaker impedance and power supply voltage are you using for the LM2876 amplifier IC?
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
