Author Topic: Strange size of a DC barrel connenctor  (Read 738 times)
Offline ricko_ukTopic starter
« on: August 03, 2020, 07:10:11 pm »
I have been spending over an hour trying to "reverse engineer" a simple dc connector and also find the mating part for a Acer monitor but cannot find any matching size on any of the distributors.
Attached screenshot of 1) connector 2) PSU label (doubt it can be of any use) and 3) monitor label (again probably pointless)
The PSU side is the only one I can measure because the mating one on the monitor side is too deep into the plastic enclosure. The PSU connector (see attached picture) has an OD of 5.50 to 5.55mm. The ID I can only measure by inserting various drill bits at increments of 0.1mm. I can insert the 1.6 by pushing with acceptable force. Maybe it could go as far as 1.7mm if the drill bit was rounded and polished like the pin of the mating part. But I cannot try I don't have 1.7mm diameter.
Bottom line when I look on Digikey, Farnell etc all the 5.0 and 5.55mm OD connectors have the ID of 2mm minimum.
1) Am I doing something wrong in measuring it?
2) How do I find the right one and it's mating part (both for in-line connection i.e. cable mount)?
BTW... I doubt it is of any use but just in case... the monitor is an Acer monitor is a G246HL.
Many thanks :)
Offline magic
Re: Strange size of a DC barrel connenctor
« Reply #1 on: August 03, 2020, 07:41:42 pm »
Try web search for "barrel jack 1.7/5.5" or "dc jack 1.7/5.5".
I'm getting some hits, although they are mostly adapters to the common 2.1/5.5 or 2.5/5.5 systems. With some patience maybe you will find bare connectors too.
I also tried 1.6/5.5 and got exactly nothing.
edit
If you need to repair an unobtainium plug, scrap the rubber mold from it, solder the new cable and isolate it with tape or hot glue.
« Last Edit: August 03, 2020, 07:46:00 pm by magic »
The following users thanked this post: ricko_uk
« Reply #2 on: August 03, 2020, 09:46:09 pm »
Thank you Magic,
Offline glentek
« Reply #3 on: August 04, 2020, 04:57:57 am »
Available on Aliexpress are 4.8/1.7, but what you want is an Acer exclusive. Search for Acer DC plug - I've ended up buying molded cords, the plug itself doesn't seem to be available.
www.aliexpress.com/item/4000316828928.html
Also look at:
https://en.wikipedia.org/wiki/Coaxial_power_connector
« Reply #4 on: August 04, 2020, 11:02:51 am »
Thank you glentek! :)
For all those who are interested, this is also a good solution: https://www.amazon.co.uk/gp/product/B07F7776T6/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
It is a full set of adaptors between the classic 5.5 x 2.1 to every other size.
