Also a comment on all these fancy pants toaster oven controller circuits. Don't bother with them!
Just stick a probe in a do a few dry runs with a bit of trial and error you will come up with easy to follow instructions like mine
1. Preheat to 40. Place board in oven.
2. Turn Oven to full (RAMP) @ 130 turn oven off. Temp will coast to 147. RAMP = 90 seconds.
3. Turn Oven to BOTTOM Mode (SOAK) and hold for 60 seconds. Temp will go from 150 - 175
4. Turn Oven to FULL Mode (SPIKE) Temp goes to 220 in 60 seconds.
5. Open door and turn oven off.
Do not follow these instructions you will need to experiment with your own oven and solder paste profile but you get the idea.
