I have an old datanetics keyboard.... board... that I want to reuse for a potential future project, I've drawn out the schematic, and I've hit a snag: I have no idea how to read the lines/columns from the key presses.
first things first, yes the keyboard works. I've got 6 unresponsive key-switches, but they're not on the same lines/columns, so it's clearly a dead key problem, and they failed open, meaning pressing them doesn't close the contact anymore. so no biggie for now.
No, it's not an apple1 or apple2 board, I have no precise answer as to what it came from, my best guess is an accounting machine, there's a separate keypad with 00 on one of the keycaps. pictures here ->
https://twitter.com/Didgitalpunk/status/1594605328615751680.
The problem I'm running into is that both the lines and columns are hooked to VCC with a 15k resistor per line/col. and that's it.... so without any extra circuitry, pressing or depressing the switch just reads 5 volts.
I don't want to mod the board, it worked in whatever piece of 70's era gear it used to reside in, I want to make it work only by interfacing to it.
anyone run into this matrix topology before? does anyone have tips on how to solve my problem?
Freya
