Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
CRD alternative
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: CRD alternative (Read 664 times)
ArturN
Newbie
Country:
CRD alternative
on:
August 17, 2019, 12:17:40 pm »
Hello,
Recently i designed some device in which i needed to limit current.
I used CRD (Current Regulative Diode).
For example this:
https://pl.mouser.com/ProductDetail/Semitec/S-202T?qs=sGAEpiMZZMtjJbtednZihoE8nwVXbu0d
My question is that what is the cheapest alternative to this device?
I found only current limiter based on JFET's.
Any ideas?
Logged
David Hess
Super Contributor
Country:
DavidH
Re: CRD alternative
Reply #1 on:
August 17, 2019, 07:35:49 pm »
I assume you mean exclusively for two terminal devices.
LM317s can be configured to provide a constant current. The LM334 is an integrated current regulator. Depletion mode MOSFETs can be used in place of JFETs. The LM10/LT1635 operational amplifier and reference is also useful as a basic building block to make current regulators.
Logged
Benta
Super Contributor
Country:
Re: CRD alternative
Reply #2 on:
August 17, 2019, 09:36:06 pm »
J507
Logged
NiHaoMike
Super Contributor
Country:
"Don't turn it on - Take it apart!"
Re: CRD alternative
Reply #3 on:
August 18, 2019, 05:01:25 am »
Depending on the circuit requirements, you might be able to use a current source based around a bipolar transistor, two diodes, and two resistors.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
CRD alternative
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
