(Not sure if this is quite the correct place to post this, but here we go...)
I'm designing a dual 8 bit, discrete DAC. Nothing groundbreaking, just a couple of LM358 s.
I have an output buffer consisting of a LM358 and an IGBT ( this one
http://goo.gl/T90Hzv ) tagged on the end as well.
Here's my Schematic -
(ignore the IGBT symbol, its just got the right footprint)
I'm having an issue where by there is an offset of around 3.6V when all of the input pins are disconnected, on every node ( except Vcc and GND). This seems to be invariant of Vcc, ive tried from 3v upto 15v, all the same. When the input pins of one DAC are pulled to ground, there is still an offset of ~1.2V on the non-inverting input. As far as i was aware, isnt that point supposed to be a virtual ground?
Honestly i have no idea what i've done wrong. I can include some of the test data as well if thats any use to anyone.
Any help would be much appreciated.
