I'm not sure if you are looking for help with an assignment, or rather working in a lab and needing a circuit to assist you with the research you are working on.
In the case of it being an assignment, I'll give you something to help you on your way. I think you'll learn a lot more from it than just finding a circuit. So think about this: what happens to the voltage on a capacitor when a constant current flows into it? And how could that principle be used to make what you are looking for?
If the latter, I'm sure others will tune in with something that will get you to what you need.
