Author Topic: 74 Series Logic Design: Equation optimiser?  (Read 740 times)
Offline NivagSwerdnaTopic starter
« on: August 03, 2020, 08:26:47 am »
I know I am about 50 years out of date but...
Given a set of Logic Inputs and a set of boolean equations (AND, OR, NOT, XOR) is there a method to optimise for a set of 74 series ICs to realise the equations?
e.g. Given a set of equations with lots of ORs the actual best solution might be to use Quad NANDs ?
Or did designers just use pen, paper and deMorgans?
Offline Ian.M
Re: 74 Series Logic Design: Equation optimiser?
« Reply #1 on: August 03, 2020, 08:53:33 am »
If you've got a windows PC, you may find Logic Friday useful.  Its a GUI frontend for the Espresso logic minimizer  The original website's gone to domain parking, but it can still be accessed, including downloading the installer, [here] at the Internet Archive.
However that wont spot for you when it would be preferable to use MSI logic chips like a magnitude comparator, or 74xx138 and '238 three to eight line decoders, which can pick out a single condition from any four input signals, or any condition with at least one '0' input from five signals or any with two '0'and one '1' from six signals.
The following users thanked this post: NivagSwerdna
« Reply #2 on: August 03, 2020, 09:35:12 am »
Thanks Ian.M
I couldn't get your link to work but I managed to find it here https://logic-friday.software.informer.com/download/
And it did the job instantly!
Online Alex Eisenhut
  • Place text here.
« Reply #3 on: August 03, 2020, 10:58:04 am »
Hmm, I'm also out of date but for small systems isn't that
https://en.wikipedia.org/wiki/Karnaugh_map
« Reply #4 on: August 03, 2020, 11:06:23 am »
... yes and minterms and maxterms and all that.  It's nice to have some tools though!  ;)
Offline tggzzz
« Reply #5 on: August 03, 2020, 11:20:05 am »
Never forget "bridging terms" in K-maps. Without them you have dynamic hazards, which can be a killer in some circuits.
Be aware that a simulator may or may not reveal the hazard, depending on whether is models "inertial delays" or "transport delays".
Forgetting about those almost allowed me to submit a synchronous IC design that would have failed (3 months turnaround, years salary NRE).
Remembering them allowed me to diagnose why a large chunk of metal moved uncontrollably until the power was cut. That one wasn't my design :)
  • Place text here.
« Reply #6 on: August 03, 2020, 05:26:50 pm »
For sure. Brings back good memories, I was pretty good at this in school... um many years ago.
It also helped me understand how the tool I was using at the time at work did its job. It made me overconfident at work, I was asked if I could take a discrete logic design and fit it into a PAL or GAL or whatever it was back then, a 22V10 or something.
Before even looking at the details I said sure! and took it on.
Turns out it was some kind of ad-hoc sequencer made with a handful of flip flops and combinatorial logic driving the sequence.
I was in trouble but somehow managed to get it to work through sheer persistence and lots of trial and error.  :-/O
On the strength of that success I was given a XC9572 design! I still have that board around somewhere. Late 1990s. Good times. ^-^
