Hmm I got another strike against the push in fuse holders,
I took apart a old unit today. I noticed in the end I had a strange part, the plastic knob came off the cap, but the metal was attached, meaning you had a nice conductive prong sticking out.
The ones that are recessed are better, because you would have to really work hard to touch the conductive part if the plastic fell off, but if its just a big thing sticking out of it, thats dangerous. A adhesive failure leaves a big conductive cylinder sticking out of the unit, perfectly connected into mains.
While it might be dangerous to open a unit up to change a fuse, might it not be more dangerous to have exposed conductor on the back of the unit because some glue fell off?
at least I won't get hurt if I need to move the unit. Easy to forget to unplug it, if you just wanna move it!
