Author Topic: Determining Tech-Ohm Ceramic Resistor Current/Power Rating  (Read 490 times)
Offline fuzzoliTopic starter
« on: April 18, 2023, 11:20:06 pm »
I picked up a few Tech-Ohm ceramic resistors at an estate sale this past weekend.  The resistance value is printed, but no current/power ratings.  I looked for charts based on size, etc., but no luck.  These particular ones are about an inch in diameter and about 10" long.  Thoughts?
Thanks!
Offline WattsThat
Re: Determining Tech-Ohm Ceramic Resistor Current/Power Rating
« Reply #1 on: April 18, 2023, 11:35:20 pm »
Size is consistent with the very common 225W rated ceramic power resistors. Google Ohmite 270 series for a generic equivalent.
« Reply #2 on: April 19, 2023, 12:23:51 am »
Ah, silly me!  Why didn't I think to look at the current manufacturers!  I was so caught up on the tech-ohm!  Thanks for the quick answer!
Offline james_s
« Reply #3 on: April 19, 2023, 02:29:36 am »
You can also load it up while monitoring the temperature, when you reach a power level where it settles at around 125C that's probably a reasonable place to stop.
