We need to setup some automated test equipment for production testing of an offline power supply LED driver (240VAC traffic lantern).
My idea at this stage is to purchase a programmable AC power supply (such as this:
https://www.bkprecision.com/products/power-supplies/9801-programmable-ac-power-source.html )
and a programmable multimeter for reading output current, output voltage and possibly a few other voltages around the board. I would use a bed of nails setup to probe the points of the circuit I would like to measure. (See block Diagram attached)
So I guess I would also need some kind of SCPI relay board to switch the multimeter to read different points of the circuit? What could I use for that or do I just make my own for this simple requirement?
Am I on the right track?
If I used RS232 for the communications would I need multiple point to point RS232 link between the controlling device and the instruments as there is no way I know of to have RS232 multidrop.
Test routine would be fairly simple.
Set AC power supply voltage output
Delay
Read AC Current, power factor etc,
Read Output voltage and key voltage points.
Change AC power supply voltage
Delay
If I used a PC is there software that is good to use? I've heard of Labview but haven't had a chance to familiarise myself with it and I understand it's expensive.
Or would you typically just write that software test routine yourself in C or something.
This Jig will be sent to the board loader for testing product prior to shipment as well.
So It might be good to make up a small go/no go tester for them using a microcontroller or something.
Thanks in advance for any feedback.
