Author Topic: UPS mod / hack - hook into car as an inverter  (Read 8115 times)
Offline electronTopic starter
« on: August 09, 2013, 08:34:19 pm »
Good morning,
Has anyone used an UPS in a car as an inverter for AC power?
My thoughts were to wire directly from the 12v battery to the UPS with a fuse inline. I am not looking to plug the UPS into the wall while hooked into the car.
Can I leave the original battery from the UPS in circuit
Recommended Fuse?
Disable buzzer or change to LED indication
The UPS is a Cyber Power 825AVR, max load 450watt
My project idea anyhow, as I have a long long road trip and would like to run a couple of AC powered devices.
Don't believe everything you think
alm
  • Guest
Re: UPS mod / hack - hook into car as an inverter
« Reply #1 on: August 09, 2013, 08:40:04 pm »
Can't say I ever tried it, but I would expect an off-line UPS, especially a cheap one, to overheat if you run it for longer than the original battery would have lasted.
Offline madires
  • A qualified hobbyist ;)
« Reply #2 on: August 09, 2013, 08:58:37 pm »
If the UPS is powered by a single internal 12V battery it should work.
Recommended Fuse?
I would disconnect the internal battery. The fuse could be a 40A slow blow. And disabling the buzzer is a good idea (maybe with a simple switch).
As alm already mentioned a small UPS might get quite hot if running for a longer time. If you don't need sinusoidal AC you could also use one of those cheap inverters.
« Reply #3 on: August 09, 2013, 09:21:49 pm »
Thank you for the insight.
Would it get hot if running lets say at 25% capacity?
example usage would be, 1 string of 50 LED christmas lights, cellphone charger, camera charger.
second usage, PC computer to download camera photos, and maybe send an email should there be Wi-Fi. (17minutes normal run time for this setup on original battery)
For longer run time, would a fan or two help?
I have access to an older style UPS, same watt, just not as efficient, but the cover opens up to the air and I could install a fan much easier.
Offline Stonent
« Reply #4 on: August 09, 2013, 09:37:41 pm »
It's an idea but inverters are usually fairly inexpensive.
Offline ejeffrey
« Reply #5 on: August 09, 2013, 10:48:07 pm »
Some UPSes won't power on without the mains supply voltage present.
Offline eevblogfan
« Reply #6 on: August 10, 2013, 09:13:04 am »
Hey
the UPS is build like SH**T .
1/3 of the power capacity is reqired in order not to harm the transformer . as for the switching fets .. if they run hot .( >80C on the outer body )  take some CPU heatsink and mount hem on it ...
at 1/4 of the rated capacity it will run either warm or hot . but I don't think you'll demage it ..
Yes I did it ... twice ..
one was 1200VA one . it was loaded with 700W load . and after 30 min.... there was smoking transformer ... after opening it up . I saw 400W core ...
the secoand time . I was smart ... firstly saw the power of the internal transformer . this time it was bearly 90W .... and on the UPS there was written " 500VA"  at PF of 0.7 .... that's 350W . witch is 3X more than the stupid 90W it can hold ... GEEEEEEEEEEEE  :bullshit: :scared: :palm:
I used it for only 100W load and it hold for 2Hrs .. :clap:
Offline Psi
« Reply #7 on: August 10, 2013, 09:56:50 am »
I can confirm this. I added extra large batteries to my UPS and it started to smell a bit burny after 40min of running on battery. (original batteries only lasted ~10min).
It didn't stop working, just yeah, smelled quite hot. I cut some holes and added a few fans and it was fine after that.
But yeah, it needed the mod to work continuously.
Offline amyk
« Reply #8 on: August 10, 2013, 11:08:21 am »
Except for the LEDs those are all low-voltage devices. A direct step-down from the 12V rail on the car will be far more efficient.
UPS inverters are built down to a price, so they are not going to be very efficient (and the overheating problems further point to this).
